- Jul 27, 2014
Thank you - I shall give this a run tonight when I get home.
That was the plan originally but I don't know how to use the parting tool. I'm a bit scared as I might break the HSS tool...
Do you recon I should run at around 100rpm for parting then? I could give it a go tonight and see.
also do I need lube?
I have to assume your machines a wee bit larger then a 7x14 ahahaha.
