- Nov 25, 2015
- 8,353
I was out mowing the other night until I couldn't see anymore. My tractor lights are a joke. I have a Simplicity 16lth.
I was looking at https://www.harborfreight.com/3-in-led-flood-light-64322.html or https://www.harborfreight.com/autom...f-road-lights/6-in-led-flood-light-57190.html.
The 3" does not say if the 3.79 in. is with the bracket or just the box. It has a 335 foot range if you believe it. Yet the 6 inch bar with more lumens is 252' range.. so something is off.
I am looking for recommendations on lights if any of you have used either, or another commonly available light. I don't want to spend a lot.
I have 3" to work with in height to fit the light into the existing spot, otherwise I would have to hood mount it on top or the sides, and I don't really want to do that. I would just like to replace the lights that are in there by removing the whole existing light bar and fitting the new light and doing whatever I need to. I want to use the existing wiring, I'll probably add an inline spade lug fuse
