I need to machine a sliding 3/4 or 1 inch diameter in a pipe tee and fit same diameters in the tee, thus needing to remove the pipe threads. I tried several ways to locate in lathe or mill, but lack of reference surfaces on the rough casting exterior of the tees is challenging and I have not figured it out yet. Pipe thread also makes locating difficult. I am going to try to put a threaded pipe in one end and turn the other, but then what do I do to locate to do the other two bores and hole a +/- 0.010 tolerance and perpendicularity.
My other option is to use a two inch diameter rod and bore both and weld. Tees would be easier and cheaper.
Suggestions?
Bob
Suggestions?
Bob
