The same went through my head as I was looking at it. This machine is very well build and as heavy as hell.(All the parts is cast iron). Would be nice if one could find its origins and when it was made ...
Hi , is it the same model?
I have looked around the web but cant seem to find them? I paid about $ 200 for it but got some reamers and new taps on the deal as well ...
looks like the valve grinder, the small pulley on the side was attached to a cable that then turned clamp that held the valve. That way you had the valve and the grinder wheel turning to give you a better face on the valve. You should be able to make a nice setup to replace the head where you can grid tools without much trouble. Nice find.
