- Nov 14, 2016
- 3,041
Atlas/Craftsman machines can cut a very wide range of threads including metric- and the charts make sense (unlike some import machines)
so if it came with a full set of gears I wouldn't hesitate to recommend a change gear machine to a beginner. Saves money initially and the
experience of working with individual gears helps with the overall understanding IMO
Then one could move up to a QC machine later as funds allow
-M
You can add a QCGB to these lathes fairly easily can't you? Sears sold the QCGB separately and the Atlas / Craftsman lathes seem to be the most common that I see this done, so assuming it is a pretty strait forward project. Of course there are also a lot of them out there which contributes to how many I see being converted.
I don't think a lack of qcgb is a deal breaker. I made as lot of cool stuff and learned allot over 8 years with a jewelers lathe and then an Atlas 618. I can't tell you how pumped I was to get the atlas and not have to hold the motor down in a cut. I learned how to single point threads on that lathe, both SAE and metric. That's not too say I'm unhappy to have a qcgb now, but lack of one shouldn't be a reason not to buy a certain lathe starting out.
Agree, particularly if seen as just a starter lathe purchase with the idea that it will eventually be replaced with something else. Buying a "forever lathe" then a QCGB would be high on my list of options.
