- Feb 18, 2016
- 451
I currently have a Chinese HQ-400 lathe/mill. (also sold as an ENCO 109-1005)
I've been tooling it up quite extensively over the last couple months. All the while I've been flirting with other lathes. I've been looking at various South Bend and Sheldon lathes. And drooling over the thought of owning one.
In the meantime I've been doing quite a bit of machining using this little combo lathe/mill. I've been using both the lathe and the milling head extensively. Thus far I've had very good results with every project I've done. My biggest complaint with this lathe is that it doesn't have a quick-change gearbox. But I've been discovering that changing gears out manually isn't really all that bad.
Today I needed to use the lathe. I had previously done a milling operation so it was set up to be used as a mill. So I had to convert it back into a lathe. No big deal, but the thought came through my mind how nice it would be to have two of these machines so I could leave one set up as a mill and the other as a lathe.
I looked at the empty corner next to the lathe and thought to myself, "Boy another one of these would fit into that corner just nice. Sure would be nice to have two of these!"
Then I started thinking that this isn't such a bad idea. This machine has a very small footprint, it runs on 110 without the need for a VFD, it has a large swing of 17.5". It does both milling and lathe work. And thus far it has been more than capable of handling everything I'm likely to do. Having two of these identical machines makes a lot of sense too as all of the tooling would be interchangeable.
Then I started thinking, "I actually like this lathe. I like it a lot. Darn it, I think I'm falling in love with it!"
So now what do I do?
Should I start looking around for another one like it and just have two of these instead of dreaming of buying a more expensive larger lathe?
From a practical perspective having two of these would actually be more realistic for the type of projects I actually do.
