[4]
indexable carbide cutoff inserts- What fits what?
[3]
[10] Like what you see?
solo
H-M Platinum Supporter ($50)
Mar 23, 2013
69
I have a Sandvik holder, inserts are 26.00ea. Holder size is 1 1/4" high 3/32 wide, inserts .120 wide. N151.2-300-5E
I ordered some I thought would work @7.00...TGTN-3 from TTC. Nope. I called, tech guy suggested TGFN-3 from T&O...nope still will not fit the Sandvik holder. Does each manufacture, have their own inserts, that will not exchange with other holders? Can anyone steer me in a direction? I haven't had any luck looking on the net. Thanks Solo
SamI
Active Member
May 31, 2018
177
The ISO designation system makes it relatively easy to identify inserts and select the right ones however I don’t believe that they cover grooving and parting tools. A number of manufacturers have their own grooving / parting systems that are only compatible with their inserts. I have two parting blades which it appears that tips can be interchanged between them however I suspect this is more down to luck than any kind of standardisation.
Unless this tool is for a specific operation it may prove more cost effective to look for an alternative parting system.
solo
Mar 23, 2013
69
Thanks, that's kinda what I figured, when I couldn't find any kind of chart. And spent $$. I see another holder coming soon. The parting tool is just generic cut off of parts at work. Nothing fancy. I may buy two blades, another one to fit the other inserts that I can't use.
Thanks Solo
I have no ideal why this double posted?
solo
Mar 23, 2013
69
Thanks Solo
[5] [7]
