Hello
New member living in Concord, Va., retired mechanical engineer, hobby machinist, woodworker, mechanic, do it yourselfer, neighborhood fixer, etc.
I have owned a SB 9A lathe purchased used many years ago, reasonably in good shape and came with many accessories and new spare parts.
One of the items is an indexer of sorts. I am seeking some help with it. The housing fits in the cross slide rotating mounting hole. One end of the shaft accepts a lathe chuck. The other end accepts the index plates. Two of the parts have mfg numbers. It is painted SB gray. When I got it it had some rust inside and did not turn freely. I took it apart, chased new bearings, and put away in box for years. I was not smart enough to take photos at that time.
Would someone know what it exactly is, how it is used, user manual availability, and bearing orientation? The bearings have a boss on one side and therefore proper orientation required.
Thanks for your help. And yes the smart phones are a great picture taking asset!!
Tom
Tom
