- Nov 25, 2015
- 8,412
I repaired this intermatic timer 2 or 3 years ago. The lobe wore off and it stopped shutting off.
I had used JB weld then to bring it back to length.
I now am back to the same problem.
I was thinking of cutting the lobe off, and gluing and pinning a new piece on.
I was thinking brass, and 0.039 music wire 2 pieces as the pins.
My thinking is the brass and pinning may last longer. I am concerned that machining after might be too much stress on the joint, so may decide to create a part before and then drill and mount it.
On the other hand aligning the part correctly might be tough, and drilling and mounting might be easier, then shaping.
The material is 0.158 thick at that point.
Looking for opinions on how to go about it. They don't sell parts for the intermatic timers (GRRRRRRR). Actually intermatic has gone to my list of crappy companies.. the product is good, but support and parts are not.. quite awful.
And it's very expensive to replace this for what it is.
