- Jun 7, 2013
- 10,110
You are correct, carbide does not like low speeds, it will break down; an exception to this is using very hard grades of carbide on quite hard steels, such as the old Kennametal K6, it will accurately cut steel up to nearly 60Rc, although ceramic type tools work even better and at much higher speeds; where I apprenticed, one of the regular jobs was to rough turn rotary shear blades to remove nicks, then finish grind them; these were about 24" diameter and 2" thick and in the high 50s Rc, then a guy doing it tried ceramic for finishing them; revved it up, and the chips went straight up in a ribbon, nearly straight back down from a height of about 20 ft! a pair of these blades were used to trim the edges of plate up to 1" thick, 40 ft long in the production of line pipe.
Also, carbide especially does not like threading without a run out relief; try to pull out like you do with HSS, and nearly guaranteed is a chipped tool.
