- Dec 27, 2017
- 340
The other day I was doing some slot milling with a .250" 4 flute carbide end mill that I had purchased in a set of 5 from eBay. I believe they may have been from "online carbide" or something like that. anyway, these slots were .350" deep, .275" wide and 2.000" long. I usually have my mill running 3000rpm with a 24ipm feed rate which gives me a .002" chip load. My depth of cut was .075" deep and this material was regular hot rolled with the surface layer removed. I had my program set to run a 2 deg ramp angle and to get my .075 depths, so no plunge cutting. With this setup I was able to make it through 6 slots before I started hearing changes in noise and a few sparks. I checked the end mill and the corners of the corners were all chipped. One of the HM members suggested that I may just be going way too fast and should try again with less chip load. Sounded like a good idea to me.
I guess my impression was that carbide liked an aggressive cut and could handle hot rolled with no trouble. The performance made me start to wonder if perhaps those end mills are not very good or possibly just my zeal for watching end mills eject purple colored chips like a lawn mower.
