- Feb 7, 2013
This morning after looking over my quick change tool post setup, it looked to me that increasing the surface area on the
base might be an improvement. I guess that remains to be seen but that what I was working on today. I used a piece
of 1/2 inch hot roll material, cut it to size from a big chunk and drilled and tapped a hole in 3/4x16. Also I fashioned a
washer out of some unknownium hard material which was also threaded and welded on to the plate for a little added
holding power for the threads. So you can comment if you wish as to if this is an improvement or not. It was fun to
run some machines and get my hands dirty as usual...It looks to me like the compound casting was broken at one time because of the recessed screws and plating. It seems to hold fine but if I have
gained any rigidity then I will be able to claim it to be an improvement. So there, that's my story today.
