Sire, probably fine (it is not my machine). I am a proponent for following the manufacturer’s guidelines. If it calls for 22, then go get some ISO22, it is common, easy to get and not very expensive.
I have quite a few machines, the gear boxes / spindles all look pretty much the same - the OEM recommendations (I have the manual on every machine) recommends ISO 22, 32, 46, 68 & 100, What that says to me is that it probably does not matter, but it isn’t a big deal so I try hard to follow the manufacturer’s recommendations. The machine with ISO100 was complaining (hot, loud), it is much happier with the 32 oil.
I think the manufacturer might specify an oil that can be used across the entire machine, acceptable for gears, plane and roller bearings, and the sliding surfaces, transfer screws etc. even if it is not the most ideal.
My SG specified ISO5, which I was having trouble finding - so I used ISO10. It ran very warm - I tracked down some ISO5 and it now runs nice and cool.
In other words, often it does not matter. Sometimes it does.
