Hi Everyone,
I have taken my Heavy 10 apart to change the felts and while apart I am refinishing it. I am in the process of re-assembling parts of it and I am working on the gear box. It is the extended threading double tumbler gear box.
I took the brass shims out (should have left them in) thinking I was going to replace them, but they measured out to be ok, so I ended up putting them back in. They are lined up with the oiling holes as expected. I have brand new open and closed bearings I will be using.
My issue is that after trying to install the first shaft (top) and the gears for it, the shaft is very tight and will not rotate. I did get the two gears that are supposed to turn freely to turn fairly well as I oiled them after they were install and they loosed up a bit, but the keyed gear and shaft will only turn using a wrench. In the manual I have for refurbishing the lathe, it says that even after all of the other gears are in, one should be able to rotate them by hand. There is no way I could do that.
I am wondering if this is normal and that maybe I just need to let the oil soak down for a while. I have also thought that maybe the shafts need to be turned to 'set' a bit into the brass shims. I was thinking of maybe using my drill to turn the shafts and let them oil up well and work their way back in.
Am I missing something or is this somewhat normal. It all came apart fairly well, but I can't say I tried to turn the shafts or gears by hand at that point to know how stiff they were. I don't want to ruin anything, but also think it probably has as much to do with not being oiled well yet either.
Thanks in advance for any info.
