Let me see if there is something I can part with, since that would actual be usefull to me at work. We could arrange to swap something of equal low value.
I have this sliding bevel square. A Millet, made in England. I was told that it would be set by protractor then would set a bevel on a wood router, molding plainer or a combination chop saw. I image it was intended for setting a sharper or meta planer. You have a ground tool 2-6inch off the vise the would be vary helpful to set the angle up there before first cut.
Would a trade interest you?
Thank you very much for the taper adapter
Give me an address in the lower 48, yours or someone else in the community who would find use of it. Then I will send the square to whoever on your behalf.
