I've been trying to put the lathe into low range. When I move the lever to engage the gears into the spindle gears it locks it up and the belt just slips.
Theres a grub screw on the middle pulley
Take that out and put some oil in there every time you use it.
‘Also the one on the mesh gears.
they run on brass bushes with oil grooves in them.
