- Jan 7, 2016
- 3,284
If it was $1000 less I would consider it.
CL
image 20 of 24
condition: like new
make / manufacturer: Jet
model name / number: GBH-1430
more ads by this user
I have (4) lathes fresh from a local school. They ordered the wrong voltage and instead of getting transformers for each machine they made the decision to upgrade to a beefier lathe all together. These have very few hours on them. Many of the tools are still covered in the original grease. All have Acu-Rite DRO's which is a $2k upgrade. Come pick yours out today. We can load no problem. These also have a ring that attaches to the bed so they can be picked from above. Like New.
(2) Have 5C Collet Closers $7950
(2) Do not have 5C Collet Closers $6950
New: 2018
Make: Jet
Model: GHB-1340
Stock: 321357A (List Price $8,700 from Jet)
Serial Number: varies but all 2018 machines
Includes:
Acu-Rite DRO203 Lathe DRO Kit (List Price $2,198.30 from Machine Tool Products)
Jet CBS-1340A Stand (List Price $714.29 from Jet)
Jet 22-Piece Turning Tool Kit (List Price $233 from Jet) *see photos for completeness
6 in. 3-Jaw Direct Mount Chuck w/ Top Reversing Jaws
8 in. 4-Jaw Chuck
12 in. Face Plate
Four-Way Tool Post
Steady & Follow Rest
Metric Change Gear
Splash Guard
Centers & Headstock Center Sleeve
Threading Dial
Tool Box & Tools
Distance Between Centers: 40 in
Swing Range (Bed): 13 in
Spindle Speed Settings: 8
Spindle Speed Range (RPM): 70-115-190-300-460-755-1255-2000
Swing Range (Gap): 18-3/4 in
Gap Length: 8 in
Carriage Travel: 35 in
Cross Slide Travel: 6-5/16 in
Compound Slide Travel: 2-11/16 in
Swing Range (Cross Slide): 7-25/32 in
Range of Cross Feeds (IPR): 0.0006 - 0.0130
Range of Longitudinal Feed Rates (IPR): 0.0018-0.0374 in
No. of Inch Threads: 38
No. of Metric Threads: 23
Range of Metric Threads: 0.45 - 10
No. of Longitudinal Feed Rates: 40
No. of Cross Feed Rates: 40
Spindle Bore Diameter: 1-3/8 in
Spindle Mount Taper: Yes
Steady Rest Capacity: 2-3/4 in
Follow Rest Capacity: 2-3/8 in
Spindle Travel (Tailstock): 3-3/4 in
Spindle Taper (Tailstock): MT-3
Bed Width: 7-3/8 in
Tool Size: 5/8 x 5/8 in
Bed Construction: Cast Iron
PreWired Voltage: 230V Single Phase
Motor Phase: 1
Horsepower: 2
Drive Type: Geared Head Clutch
Length: 79 in.
Width: 28.5 in.
Height: 30 in. without base
Weight: 1154 lbs. without base & accy's
Check out the photos to see for yourself the condition of these machines. They are great. You can also inspect under power at our facility. At the time of this listing I had 3 other similar lathes. All 2018 Jet's.
(4) 2018 Jet GHB-1340 Geared Head Metalworking Lathe 230V 1-PH DRO -...
I have (4) lathes fresh from a local school. They ordered the wrong voltage and instead of getting transformers for each machine they made the decision to upgrade to a beefier lathe all together....
minneapolis.craigslist.org
CL
(4) 2018 Jet GHB-1340 Geared Head Metalworking Lathe 230V 1-PH DRO - $6,950 (New Hope)
image 20 of 24
condition: like new
New: 2018
Make: Jet
Model: GHB-1340
Includes:
8 in. 4-Jaw Chuck
12 in. Face Plate
Four-Way Tool Post
Metric Change Gear
Splash Guard
Threading Dial
Tool Box & Tools
Gap Length: 8 in
Bed Width: 7-3/8 in
Motor Phase: 1
Horsepower: 2
Length: 79 in.
Width: 28.5 in.
