- Mar 13, 2013
- 71
I was using a wooden jig for Jeweling bolts but it was not very rigid and it was difficult to fit odd shaped bolt carriers and parts into. I had some angle iron laying around and this is what i came up with works well enough on all the bolts i have jeweled. the pictures are before i cleaned up the body and painted it. Bolts used are 1/2" with a hole drilled into the end of one to accept a pin that goes into the firing pin hole, and another drilled through to accept a pin that helps to turn the bolt. I use a marked rule spaced 3/16" apart to space the swirls on the bolt.
