Been putting off making a tailstock lock, but I finally did it. Got up the courage to drill a hole through a very expensive casting (if you can even find one). I disassembled my Jet BD920n tailstock and dived right in. I wanted a robust locking mechanism so I decided on a 5/8" shaft supported on each end to operate the lock. Most of the mods I've seen online are pretty much the same so I won't go into too much detail. I turned a 5/8" shaft with a 15/16" dia. end for the tailstock lever. I chucked it up into my 4 jaw with the shaft center approx. 3/8" offset from centerline, making sure the shaft was also in line with the lathe centerline. I began turning down about one inch of the center of the shaft, making a crankshaft like part. I then turned a sleeve to use as a connecting rod end for my 5/16" connecting bolt to the lower locking assy. For the support on the other end, I used a small (2" X 2 1/4") piece of 1/2" 6061 plate. I used an old 3/4" carbide (woodworking) router dado bit and chucked it up in my 3 jaw chuck. I squared the piece and milled it to size (yes, on my 9 X 20 lathe) by holding it in a tool holder on my QCTP. A rectangular piece is boring, so more milling. I cut the 2 corners off and then milled a ledge on the longest side of about 1/2" X 1/4". I polished the shaft and sleeve with 220 grit, then placed the two parts in heated Phosphoric acid I purchased at "Sherman" Williams. An hour or two brought the pieces to a nice dark, almost black color. It beats the cost of commercial "blackening" chemicals, but there was no way I could anodize the aluminum shaft support. I just Rustoleumed (sure, it's a word, look it up) the support in your basic black after I smoothed up the sharp edges. A quick assembly showed that all parts fit as advertised, so then I tapped the end of the shaft and made up a cute brass washer for a short 1/4" allen head screw to fit in which holds it all together. It was then time to sand the bugger and apply something close to Jet's off white color. Full disclosure: This was all written up well after the fact, and all photos were not necessarily taken in the order of the build. Now, the photos-
