- Jan 23, 2013
- 107
Bought a old Buffalo tools Rf-31 copy. I have taken the table apart and oiled it. When I started on the top I discovered a few things
The mill is pretty noisey. The pulley on motor is loose when I took it off I discovered It was cracked and had been rewelded. I think its out of round.
I have a Lathe I can use to work on it or should I buy a new one.
Also The spindle does not appear to be attached to the pulley I have about 1/4" of play is this normal should I disassemble the head
How do I oil the spindle? Theres a grease fitting on the bottom but know its to be used with oil from what I have read.
This appears to be heavier built than the normal RF-31 Its a made in Tiawan machine
R8 spindle
I got the mill an enco vise and a heavy steel stand for $400
R8 spindle
