Ok. I'll try to paint a good picture.
So, it's a 90v 2.5 hp DC motor
The 1hp current limiting (horsepower) resistor is installed, I have a 1k pot.
The motor ran fine under no load fine previously, got it hooked up to the lathe, seem to run fine, but it seems to be getting weaker the more I try it. The current limit led glows and it runs pretty slow. I've read all the manual and have tried adjusting the trim pots. I can get the motor to run better but I have to crank the current limit pot up pretty high.
No way the motor has to push 150% of 1HP to just run the lathe under no load.
And now if I take the belt off the motor, the motor hunts for the speed it's set for. I can adjust that with the IR trim pot, but again, seems to be much higher than recommended.
And the resistors get hot.
What have I done wrong? I have checked all my connections and nothing seems to be grounding out. I know some of my items are not as they should be, the speed pot, the resistor, but they shouldn't make THAT big of a difference. And the worsening performance bothers me...
