- Jan 14, 2013
- 290
This is my version of the keats angle plate that Stefan gottswinter built on his youtube chanel.
It works a lot better than the original keats as that it only has one axis of movement. For many years if I wanted to turn a cam or eccentric pin all I did was to put a shim of the appropriate size under one jaw to give the offset I needed and go at it.This works a lot easier and makes a nice addition to your lathe. If you watch his video you will get a better idea of it.
