KO Lee Tool & Cutter grinder grinding wheel question?
Technical Ted
H-M Supporter - Gold Member
Nov 5, 2016
977
I've been checking out some specs on KO Lee T&C grinders. Some models have a separate motor and belt driven spindle. Appears the grinding wheel arbor size is 5/8".
For you that run these, do you buy wheels (straight, cup, dish, etc.) with a 5/8" hole or do you make/buy adapters so you can run the more standard 1-1/4" wheels?
Comments welcome, Thanks.
Ted
Cooter Brown
863 Bronze
Nov 23, 2017
908
I have a KO lee cutter grinder and yes I use a spacer to run 1-1/4" wheels and it works great.... The spacer came with the machine, its plastic but you can use whatever you have on hand.... When I need to make one for a different thinner wheel I will most likely use delrin or aluminum....
I have been thinking about making an adapter for surface grinder arbors to mount on the KO Lee.....
AdBlock Detected
I've Disabled AdBlock
