- Nov 14, 2016
- 3,007
Understand these tools work differently the lathe tool being fixed as the work turns, the mill tool turning and the work is fixed in place.
I know there are going to be parts where the lathe is not a good choice, holes offset from the center, non-round part not easily chucked into a lathe etc. Or where everything is already being done on the lathe and switching to the mill would be an unnecessary step.
So my questions are:
As far as holes go is the end product essentially the same?
Is there any reason you would choose one over the other beyond which machine was going to be the easiest to use with the piece?
Given a piece that was equally suited to being held on a mill or lathe (say a hole in the center / end of a piece of hex bar stock) which would you opt to use and why?
