[4]
Lathe Chuck Caddy
[3]
[10] Like what you see?
kvt
Oct 21, 2014
2,036
That's a good idea but still have to lift it up on the lathe.
That is almost as bad as holding it while putting it on, and some days worse.
Winegrower
H-M Supporter - Silver Member
Jul 29, 2014
179
Can you spin the chuck while it's on the caddy? If so, I like this. Put it up there, spin it on, release.
38super
Apr 23, 2018
51
Round stock spins on a bolt mounted to the vertical piece, snug the chuck jaws to the round stock. Used a dead center to scribe the spindle height to the vertical for bolt hole location. Place the caddy on the ways, spin the chuck onto the lathe spindle. A vertical tube mounded to the base would provide a home for the chuck key. Still a dead lift onto or off the lathe, a jib crane would be nice if I had one and the room.
Used furniture wood nuts (3/8-16) to bolt the angle iron to the wood base.
[6]
[5] [7]
