Oil eater if used full strength will soften some paints, it should be diluted with water; I never had a problem with it regarding rusting, if paint is softened, it will reharden in a short time.Ok......First time I heard of it, I'll try it
Thanks
Sound like it might be similar to purple power. Starting diluted a bit is a safe way to go . If the oil is not dried on for 50 years it will clean much quicker and a quick spray and then wipe is all that might be needed. As mention full power can soften paint if it is allowed to dwell. I make a point to be careful around data plates feed charts ect The cleaner can attack poorly silk screened letters and remove themOil eater if used full strength will soften some paints, it should be diluted with water; I never had a problem with it regarding rusting, if paint is softened, it will reharden in a short time.
