- Dec 21, 2018
- 1,851
Went back and read it.Here is a description of my procedure.
My lathe weighs about 2700#s, sits on the 6 factory supplied leveling bolts & pads, No issues with wondering about.
I haven't checked for concavity with a face plate, good idea.
I was getting so hot & tired that I was trying to get it done. I had recently re-checked front to back twist with my very good level and adjusted it slightly. To get uniform pressure on all bolts I've used crow's foot sockets on my torque wrench. Not so sure that's any better than just the "feel." Didn't check end to end level as I don't really care about that. Whatever it still is from the original setup is what it is.
I did on the first few iterations but had found no measurable changes so I didn't on the last half dozen tries.Did you take spring passes after your cuts?
I need to go back and check see which end was larger. Why does it matter?
Even getting slightly different tensions on the push/pull adjusting bolts affected the rotation of the head. Or maybe it was how snug I had the mounting bolts while trying to make adjustments? Having to take the change gears and banjo off/on for each try was a PIA.
At any rate I need to go back over everything when its not so damn hot and I'm not exhausted. Then move on to the tailstock end adjustments. Thanks for the input guys.
