- Oct 28, 2020
- 20
Not sure if this is the right place for this but I know there is a lot of talent here and am hoping I might tap into the collected wisdom of those far more experienced with these tools than I'll ever be.
I'm a woodshop home gamer looking to extend my reach into metal. I have some limited experience operating a Bridgeport and have placed an order for a PM-728VT benchtop mill from Precision Matthews. That decision was reasonably-informed as I had some basic background experience there.
I'd also like to pick up a lathe for the home shop, but having never once touched a lathe I have very little idea of what exactly I should be looking for. My use cases are pretty simple, everything I tend to work on happens to be small. I primarily have been making small electronics and simple mechanical contrivances on a one-off basis. As a result, I don't foresee a need for a huge bed/swing as I'm unlikely to be turning gun barrels or what have you.
With that said, here is my entirely-uninformed-by-any-experience list of thing I think I might want. If anything in this list is dumb, I'm interested in being told about it
- Ability to cut a reasonably-wide range of materials, including most grades of steel
- Speed of machining time isn't super important, if one can get a less-massive lathe that can still cut steel but with a smaller DOC then I am totally OK with that
- Machine size in respect to the size of the work that can be handled isn't super important, but I understand that size also relates to capability and would be willing to buy a bigger machine just to get a better machine if needed.
- I'm in the US but would prefer metric tooling if that's an option
- Single-phase power up to 20A would be preferable
- This is going into my basement, which is walk-out but that still is problematic for a 1000lbs+ machine. Smaller would be better in that regard, but I can bust my hump to move something if it's really warranted.
- I have been looking at Electronic Lead Screw projects with some interest. I'm very comfortable w/ steppers and controllers etc and I think that might be a better solution for me than futzing with change gears, or spending $$$$ on something that requires less change-gear-futzin'. I might be wrong about that and would appreciate input.
- Precise enough to hold a thou with care and some work
- An available DRO option would be preferred
- Don't really care about CNC for this tool
- Strong preference for a machine that doesn't require a lot of screwing around before first chips to make it not suck. Buying a cheap chinese tool is OK, but if I need to be an experienced machinist to do whatever work is required in order to make that machine safe and reliable, then I have a problem because I am not an experienced machinist. As a result, for my first set of tools I'd prefer to purchase something that is reasonably reliable straight out of the box. Once I start understanding this stuff then I can go trolling CL for some clapped out Bridgeport treasure find (and then subsequent rebuild).
