- Apr 12, 2012
- 579
I just temporary leveled the lathe and made my own on it.
Steve
Steve
Which leveling pads would yall recommend for the PM 1340. http://www.machinetoolonline.com/PM1340new.html
I have been looking though all the leveling feet, and getting too confused. 1/2" studs, 5/8" studs, 2" pads, 4" pads, 500lbs, 2000lbs, 6000lbs? I just don"t know which ones. I need 6 of them, and i am looking in the $20 to $30 each range.
Thanks,
Jonathan
Jonathan,
You'll need pads with a stud that will fit through the holes in your machine base and are rated for at least 1/6 the weight of your machine. Mcmaster Carr, Enco, Travers, MSC will all have what you need,
Tom
I was figuring about 500lbs, so 500x6 would be 3000lbs. So, no matter what I turnd in the lathe the feet will hold.
I just didn't know if I got ones with rubber pads rated over 2000lbs, the rubber might be too hard to be effective.
Would these be a good http://www1.mscdirect.com/cgi/NNSRI...re=ItemDetail-_-ResultListing-_-SearchResults
Thanks
My lathe is a heavy 10x24, with a threaded spindle. Several times when removing the chuck I had to pull hard enough that the rear feet lifted.
Now I have a strap from the chip pan to the wall.
