- Dec 23, 2019
- 122
So I've had the 1340GT lathe for a while now and have done some smaller projects. All has been good. When first setting it up in its home position I was very careful about getting it as level as possible. Since its had some run-time now decided to check level again in case of settling. All is still good according to the Starrett 98-6. Had some free time today so decided to cut a test bar to check headstock/ways alignment. Using 12" piece of 2.5" 6061, faced the ends, center drilled and relieved 8" between the bands to be test cut. Did the test cuts and had a .0031 difference in 9". I was able to get it to .0004 by adding twist to the bed via the adjusting legs on the bench. On the level now it shows about 3/4 of a line difference from headstock to tailstock ends. It's a mental thing, but I don't like having it out of level even though the end result is better.
Would it be better to adjust the headstock angle and keep the bed level? Opinions?
