- Nov 9, 2018
- 377
Hoping some of you guys might help diagnose the spindle noise here. This is a Clausing, but Atlas, Logan, and probably many others use the same back gear design.
There is a very loud, persistent noise coming from the spindle with the bull gear engaged (direct drive), but no noise in back gear, or free wheeling.
Just cleaned, inspected and re-assembled the spindle assemble, same noise as when I first got the lathe.
The main bearings seemed OK by hand, and there was no marring on the races, races looked almost perfect. There is some wear in the back gear bushings, and I plan on making new ones.
I’ve tried adjusting different pre-load and no difference, right now pre-load is adjusted according to manual spec, in the spindle spins freely for about 1 revolution. Tried adjusting the collar that presses the drive pulls against the spindle with no difference.
If you turn the spindle by hand, in direct drive, and keep your hand on the main drive pulley, you can feel a slight rocking about once per revolution. This would seem to indicate that the bushings are damaged worse that I thought, possibly worn in an eccentric. So could a slight rocking of the main drive pulley be responsible for such noise?
I’m at a loss, because this noise does not sound like any bearing noise I’m familiar with.
In any case, I bought material to make new bushings. Do you suppose that with this noise, the lathe is good enough to make bushings on it (I don‘t have access to another lathe, have to use this one to make parts to fix itself).
