- Nov 28, 2016
- 2,357
I'm working on getting an old Hendey 12x30 gearhead lathe operational... the lathe originally left the factory with a 5hp 220v 2 phase motor.
At some point in its life, the motor was replaced with a 5hp 220v 3 phase motor... all of the other electrical components were removed except for the forward/stop/reverse switch assembly. Apparently, that is as far as the motor installation went... the motor was never wired up, I don't believe.
I'm looking to get it operational... and was wondering which way to go with the motor controls...
Option 1 would be to keep the existing three button switch assembly and use a reversing contactor like this...
Option 2 would be to ditch the existing switch assembly and wire it through a drum switch like this one...
I'm looking for pros and cons on both options... and information on which is better, and why.
Both of the units above are on ebay... all things considered, the cost difference wouldn't be a lot, but the contactor is used, where the switch is new.
Thanks...
-Bear
Thanks...
-Bear
