- Apr 4, 2016
- 872
I am just throwing out a general question/idea concerning lathes with threaded spindles. Over the past years I have read numerous comments about the caution required when reversing rotation of the spindle on these lathes. I'm curious if anyone has considered making a modification to their chucks to help prevent unscrewing when running in reverse. I was thinking that if I had one of the smaller lathes with the threaded spindle, I would consider drilling and tapping the chuck hub radially in probably three locations and using some of the soft tipped set screws available on the market to help prevent unscrewing of the chuck. This method may not work well on larger chucks just because of the inertia of the spinning chuck, but it seems that it may work for smaller chucks. Is this a bad idea or are there other better remedies ? The link below shows the type of set screws I was thinking of.
http://www.ondrivesus.com/precision-fasteners/tipped-set-screws?gclid=CPG9tInjic8CFZSPfgodvxsH1w
Just some food for thought.
Ted
Ted
