Lathey Susan
rwm
Robert
Mar 25, 2013
4,617
This is pretty simple but highly effective.
I ordered one of those ball bearing rings from China.
3pSwJa6CMUKtM7x40Bt31D0EWuWDLre7LNIAR-mvf69zTPZeatvNZVq4mGsMDntiGM5T2Htj6hgeNsqoP=w1902-h1075-no.jpg
cqGqyTVP8rrBB_O9_XsVVqZpczqxRcVaz2xU-mddJ3A4RWIClWzhSexqSvNWMXhq4NmUy7Ny0ozBgJ79j=w1902-h1075-no.jpg
15" Plywood disc. Largest that would fit in the cabinet.
c6MtNf3a7gxNSrpRJem8uv-bbZhRTfsvo7cxA6Z3fHIzml_qLOlZr9kdXVrjP82XoyE8VDYNO-8gn6JlI=w1902-h1075-no.jpg
FYqvZ9CTyRakJ0ZOJNNRsvaHerM32kbcxXrbpad9fBN3tKEQGdZzWi8-6yN52Zek7cug5u0HxglNhFE7Z=w1902-h1075-no.jpg
(1) 8" and (2) 6" chucks.
ZRftzUKH7KQfE9wKl_jDErevu6AzZ-r69k7pvNbSq5h-icmK7I6i6jdOk2ihJC1jABdkaiB126SNwetuZ=w1902-h1075-no.jpg
b2tcDMkNPj2QjIipgF_6z-v8RgDDWPpYqxoliqAkeL1IGwmpG2TAUqiCyxIZ_E7QWGy-dVCt_X7oymncq=w1902-h1075-no.jpg
This turns very smoothly and works great. No more moving several heavy chucks to get to the one in the back.
R
looks nice, those bearings I hope will hold up better than any of the ones like that I have seen.
Very creative and can be utilized for a bunch of different applications.
The bearings seem strong enough. The capacity is rated at 120lbs. Have you seen these fail and how? I would certainly not use these for hubless motorcycle wheels!
R
I like that idea. The only way that I see that failing is a soft ball race and hardened balls. The ball race woud wear fast with the weight on it.
"Billy G"
Billy that is exactly the way it look on the ones I have seen fail is that the race was soft letting the balls dig into it under weight.
R
Great idea. I've been wanting to do something similar in several areas of my shop.
Do you have a link? My google-fu is weak.
