- Dec 28, 2022
- 253
I can cut fine if I engage at the same number every time.You need to cut a full thread. Do not run it in reverse with the threads engaged. Back out then reverse. Go far enough back out to allow any backlash to be removed. If it will cut the threads correctly over all those passes. You may have fixed the issue with the half nut gib adjust. If notI think might you have something loose like your gibs or other components. Go through and make sure everything is tight and gibs adjusted correctly cross slide and compound.
Cutting oil is my blood.
