- Nov 14, 2016
- 3,041
I've built quite a few workbenches over the years, my go to is a plywood base for strength, with an easily replaced 1/4" Masonite top if I want a smooth surface, or a sanded plywood top if I don't care.
Plywood has the benefit of being tough, and fairly cheap but untreated will absorb chemicals / oils. With a piece of Masonite it has a cleaner appearance and can be easily kept clean. When the top gets too beat up, it is cheap and easy to toss it and put down a new piece of Masonite.
I see hardwood tops seem a popular option, although I'm not sure what their benefit is other than being more attractive than a similarly thick plywood top.
Synthetic kitchen counter top materials can often be had cheap, are fairly tough and easily cleaned, but with a pressboard base don't take pounding as well as real wood.
Metal tops obviously have the benefit of durability, and conductivity (welding).
I just picked up this sturdy work table. My plan is to enclose the sides with thin plywood because it will be going into a corner where anything escaping behind or to the left side will pretty much be lost to the void for all eternity. I'm debating on what to do with the top. It looks like it once had a small lathe bolted to the top, and the top has a lot of old oil staining. Some bits of swarf I found in the drawer is another clue to its earlier use.
I can leave it as is with its (to me) attractive age and patina, but it is pretty rough so I'm leaning towards just dropping a new piece of sanded and sealed 3/4" plywood over the existing top. I see there are a variety of hardwood tops (most Maple or Birch) I could get for $100-150 (which is 2-3x what I paid for the table). Really not sure that this offers a benefit beyond appearance. This will be tucked into a back corner of the basement where few will see it.
My primary use for the table will be to finally have a spot set up for reloading and small gunsmithing projects, but of course being a small shop area any flat surface becomes a work area.
Looking for some other views on workbench tops. What is your preferred bench top and why do you like it?
