B will not give you a reference for "leveling"the lathe. You can compare readings down the lathe but not for level just twist. Those two V surfaces are different heights measure them to the flat surface.
A would give you two surfaces on the same plane. Keep you blocks on the same side down the whole length of bed do not mix during reading trying to position in the same spots to take variables out.
