- Nov 8, 2011
- 1,678
I have a Lincoln Procut 40 plasma cutter without a torch, I have the whip but no torch. Do any of you know how to test it to see if it's ok otherwise before buying a torch?
I work on Plasma cutters and Welders for a living and I recommend that you take the machine to a qualified repair shop. The output voltage and current levels on all Plasma cutters are more than able to kill. Don't take chances with this at home.
300.00 Bucks is about the going price on plasma torches Charley. It might be worth dropping by the Lincoln dealer and seeing if the have a way to test and insure the power source works first. I'm like you I would hate to buy a torch and the Power supply is no good and I couldn't return the torch...
Bob
