- May 27, 2020
- 1
Hey ya'll, I have yet another, "what mill should I buy?" question. I used to have access to some big mills and lathes (bridgeports, jets) from my university, but recently graduated so no longer have access. I'm looking to start building up my own empire of dirt and wanted to start with a mini mill. A little tight on space right now (and power available in said space), so a larger mill isn't really an option. I'm really only looking to work with aluminum and softer materials, no steel.
After looking through some other "what should I buy" posts, I've noticed there's fairly high praise and recommendation for the LMS 3990. However, I've noticed that there isn't much mention of the LMS 4962 (Sieg X2D) at all, which is the mill I'm currently leaning towards. Is the lack of mention due to it being a bad/poor mill, or just few people owning one to make adequate comments on it? From LMS's comparison page, the two are identical on paper, aside from the motor. If that's the case, I'd be willing to save a few dollars now and do a motor conversion later on down the road. But if there's something detrimental about the 4962 that I just haven't found yet, then I'd rather save up a little more for the 3990.
I'm also open to purchasing an older used machine, but haven't had much luck finding one online in SE US (craigslist really). However, I'm not sure what sort of machines might even be out there that would be worth investing in. I'm looking to do a CNC conversion down the road, and I've read that round base mills make that difficult/impossible. I had found recommendations for the Rong-Fu lineup, but it sounds like the round base makes it a poor candidate for a CNC conversion. What other brands/models that I should be on the lookout for that would be good for a conversion? Also, how often do mini mills seem to pop up on craigslist? Is it every few weeks, or every few months?
Thanks for the help!
