- Jan 17, 2016
- 71
I just picked up a Logan 11" Model 940-2 Lathe. It has a base cabinet with a variable speed dial and Quick Change gears. I was able to run it and make some cuts. The spindle has very little run-out and the ways seem to be in good shape. It has a square/flat top on the spindle head and the gentleman I bought it from had it off and it has a oil bath for the gears...he wasn't sure that it came that way or someone decided that would be a good idea? It runs smooth and quiet and took some decent cut. It needs some TLC on the paint and the teeth on the manual carriage gear are worn, but it still works (has some lash tho). It has the 2.25x8 spindle thread and a 1 3/8 spindle bore.
(Serial # 65959)
Any info on the gear lube bath and where I might get a carriage gear and manual?
I'll get some pictures up tomorrow.
Any info/suggestions on anything else to check would be greatly appreciated.
Thanks!
Terry
(Serial # 65959)
Thanks!
Terry
