Logan 14 Carriage problem
John_Dennis
Mar 5, 2014
381
My Logan Carriage will not completely disengage the cross feed. You can stop it with your hand but it turns when I let go.
Also the drive screw has the points worn off the threads near the chuck. seems like an un=natural wear pattern.
Can I take the carriage front off without the parts going everywhere? How involved is that?
Thanks
John
The carriage came off without any problem. The case was filled with heavy gear oil which may be too thick for this machine. The cases are glued together with silicone sealant and I can not get them apart.
The feed screw bushing is badly worn. Anyone know where to get a new one? the shaft size is 1.12 inches
Thanks
John
Also;
Know that bronze bushings tend to be very standardized, and as such an be found many places. McMaster Carr is a good example.
