Logan 1875, Proper Lubrication Questions (Grease Zerks or Oil Cups in QCGB?)
Just got this Logan and have some tooling and lube ordered. I ordered Mobile Spindle and Way oil per Logan specs in Manual.
The manual points out all the lube points (Almost) and says to keep the ways oiled. It also says to keep a small amount of graphite grease on all the gears in the head stock, apron and rack teeth under the front way.
What I don't find in the manual is the QCGB lube requirements. Mine has three grease zerks. Wondering if they were retrofitted at one time and if they should be the little oil taps like the rest of the lathe has.
You can see two of them in this pic. The other is behind the back gear cover. I can take a better pic if needed.
What do the experts think? Grease or spindle oil?
