If anyone here has a Logan 200 would you please post a photo and dimensions for the plunger that releases pressure on the pulleys in the drive when you raise the head stock cover. I also need the same for the adjustment screw that pushes it down. The screw threads through the cover. I believe the part numbers are LA-366 and LA-378 if you have the manual.
Thank you
Scott
Thank you
Scott
