I am about ready (after much delay) to finish up rebuilding my Logan 200 flatbelt when I realized I was missing (among other things) the pulley that attaches to the motor shaft. I was going to just approximate based on the size of the gaurd, but I didn't know how much that would throw off speeds in the gearbox. If someone could just give me a quick measurement it would be much appreciated.
Also for the motor speed. I did have the original (or what I assume to be original) 3 phase motor with the specs plate that I will not be using. However the specs plate seems to have run away. I did remember it was 1/2 hp, but I forgot if it was 1750 or 3450 rpm. That being said he is likely to come back home sooner of later, but the motor pulley is the more pressing issue at present. Again any help would be great. Thanks.
