Since we are on the subject;
It occurs to me that the lack of any real ability to lube the back gear shaft sleeve bushings, and the difficulty in getting that shaft out for periodic maintenance, is unfortunate. I had been toying with drilling and tapping a small hole in the outer sleeve so that I could drizzle some oil in there that would find its way out to the bushings. A very short bolt would be used as the hole plug.
Opinions?
I guess it couldn't hurt. The shaft runs on oil impregnated bushings. If you have it apart you're probably going to clean and oil it before you reassemble it. I don't run my lathes in backgear a high percentage of the time so it isn't really an issue for me. I've taken a few of those shafts out and I haven't found any extreme wear even on some pretty used and abused machines. I can guarantee you if Logan had put oilers back there, the only time they would have seen any lube would have been at the factory. The coolest addition of oilers I've seen is on the saddle fore and aft of the wipers. I haven't personally done it but the Sheldon lathe I have now has them. They appear to be original equipment. When I read the thread about doing it on a Logan I didn't think much about because I use way oil liberally on my machines. After using them on the Sheldon I'm really sold on the idea. It's pretty impressive to see how well it keeps the ways lubed.
Chuck
