- Nov 22, 2010
- 371
hey guys,
i am rebuilding a logan 825 ( Cabinet w/ underdrive version of an 820).
My clutch doesnt work and Upon disassembly i cannot find any spring that would be required to allow the clutch to engage or dissengage when the clutch knob is truned to allow the clutch to do it's job.
Looking through the Logan purchased " Operators instruction Parts list for model 825 and 845 I note that the pages are not numbered but in the top right corner is marked O-4
on the upper left of that page there is a drawing of the clutch labled LA-54 at the top of the pageshowing a part number LA-238 that is called a spring and it requires two such springs that would be smaller in diameter than the springs on a ball point pen. There are three holes at the location, one of which has a drive pin in the shaft but no springs...just wmpty hole about 3/16" deep.
On the next page 9 with O-6 in the upper right corner and labled LA-54-2 worm & clutch assembly is an exploded drawing of the entire clutch worm assembly which shows a spring labled LA-519 that is located IN THE DRAWING in the center of the shaft assy. but may not be where it actually resides during use...but may in fact reside inside the clutch disks and actually be the tension necessary for the clutch to work.
long story short.... What am I missing and what is the part number
My lathe is an 825, serial Number 43469 ( older version) anyone able to help would be much appreciated
Joe
Joe
