- May 31, 2014
- 44
Looking for a parts diagram for a Logan Model 1922
My machine is missing the Spindle Gear which drives the forward/reverse tumbler gear. I have sourced the gear, but I am missing a threaded collar for the end and I assume some other spacer that keeps the gear in position to ride the tumbler gears??
My machine also has a lever for the clutch engagement, it doesn't seem right and I obviously can't test it out right now without being able to drive the lead screw. I think it's missing a spring inside or something. It's just solid and wont engage left or right unless I take the nut almost off which holds the lever.
Anyways I have already looked at www.lathe.com and didn't see manuals anywhere.
Even if someone can post up some photo's that would help. Thanks in advance
