Logan Problem
richz
Jan 19, 2012
159
Last night operating the Logan I saw that when releasing the carriage or cross slide feeds the knobs kept turning. I can stop them with my hand but would like to them to stop turning when taken out of gear. Anyone have an idea of where I should look to solve this problem?
Winegrower
H-M Supporter - Gold Member
Jul 29, 2014
874
There is a clutch on the feed mechanism that is just a bit too tight. Look for a couple of jam nuts on the apron and back them off slightly until it does not slip while feeding but stops when the clutch lever is released.
richz
Jan 19, 2012
159
Ok I know were the adjustment is but why did it just start happening?
wa5cab
Downloads Moderator
Staff member
H-M Platinum Supporter
Dec 25, 2011
8,233
I don't know what the clutch looks like or where it is located but the only cause that comes to mind is that maybe some shavings or metallic dust could have gotten in it.
Winegrower
Jul 29, 2014
874
Why does anything just start happening? I’ll leave that question for the philosophers.
lordbeezer
Sep 1, 2018
223
Has lathe been sitting for awhile.? Sometimes clutch can stick.tap knob LIGHTLY with small hammer.
richz
Jan 19, 2012
159
I adjusted it last night and its working fine now. Thanks for the replies.
bweingartner
Oct 11, 2017
9
This happened to mine recently as well having adjusted it in the summer. I attributed it to the oil in the apron thickening in the cold. Seemed to improve once it warmed up.
tmenyc
Oct 18, 2018
331
Sounds like my old VW, of blessed memory...but the clutch adjustment makes more logical sense to me, now that I've been inside my Logan's apron. Unless the lathe was in an outside shed and really cold. If that was the case, maybe you need winter oil!
Tim
bweingartner
Oct 11, 2017
9
Lathe was probably ~40F at the time. Considering it was -23F outside, I'd call that warm!
AdBlock Detected
I've Disabled AdBlock
