Looking at a decent condition Heavy 10 locally. Price is pretty good for this area
They put up a video of it running under power. Could of things the noted and I saw.
1. Half nut and manual feed work, but the cross feed doesn't. Looking at the parts i would guess this is a clutch issue or the gears are damaged. Anyone seen this and know what may be the issue. I can't remember if the non half nut feed worked.
2. Gears are pretty noisy. I looked over all that I could without tearing the machine apart and saw no chipped teeth. It sounds like loose meshing. Is this adjustable or is it a sign if something wearing out.
3. Finally there is a chunk missing of the main casting directly below the front motor door. It looks like it was painted a long time ago and isn't spreading. Is this any cause for concern?
