To start, I have Central Machinery Mini Mill. (Yes, Harbor Freight, but hey, it was partially a gift). I converted it to a belt drive to get rid of the plastic gears that break every 3 months but other than that she's stock.
I have a hobby of restoring high end putters for people and its getting quite busy! Any custom work like Welding or milling I send out to get done. Which is fine, it just adds time.
All I'm looking at doing is cutting small holes or "dots", and small lines into 303 stainless. Sounds simple, but I don't know if my mill is junk, or if I'm not running the bits at the proper speeds.
I did a practice run with 1/16 end mill. Ran it as fast as my machine goes (2500 rpm) and cut as slowly as I could, and it tore the teeth right off the coated carbide bit.
I can punch some dots decently fine, but still would love to know what speeds I should be using.
The size bits I'm using are:
1/16
1/8
3/8
1/2
Any tips would be great. I feel these are simple enough tasks that I can do it, just need suggestions to make the work as clean as possible. Thanks!
1/16
1/8
3/8
1/2
